Use the following procedure to display the monitor-by-isid entries on the monitoring BEB.
Switch:1>enable Switch:1#configure terminal Switch:1(config)# show monitor-by-isid 3 ============================================================================= Diag Monitor-By-ISID ============================================================================= ID MONITOR_ISID ISID_OFFSET EGRESS_PORTS EGRESS_MLT MAP_TO_VLAN ENABLE ----------------------------------------------------------------------------- 3 16776000 1 1/4, 1/5 1 999 true -----------------------------------------------------------------------------
The following table defines parameters for the show monitor-by-isid command.
Variable |
Value |
WORD<1-1024> |
Specifies the session ID list ranging from 1 to 1000. |
